GUIDE: The Mk2 Leon VAG-COM Guide
Daveb77
287
11
leaving home...?
thought i was smart by working out how to switch on leaving home lights for 40secs yesterday. Just noticed though that the lights will always come on when car is unlocked, even with lights not in the ON position (if that makes sense?). Not really a big issue but would have liked it to perform as per the coming home function (i.e. lights left on when unlocking car). Is there a check box somewhere that im missing to do this?
any tips would be appreciated,
D
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
no, it seems to depend on age of car/which control module is installed on the behaviour. Mine is like yours, always comes on regardless of switch.
alx_chung
Dark Lord of the Torque
Sep 11, 2006
1,538
In front of a PC....
Just found one that might of use for people with aftermarket radio installs where a Scan will throw up the following error:
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 206
Mileage: 57709 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:35
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 57709 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:40
A more indepth explaination can be round on Ross-Tech here.
Do the following:
1) Clear the DTC
2) Go to 19 Can Gateway
3) Installation List
4) Uncheck 'Radio' and 'Navigation'
5) Apply/Save Settings
6) Turn car off
7) Turn car on
8) Run scan again
And whola error gone :D
Alex
singh123
Cupra
Mar 17, 2008
290
Hi guys i wonderd if one of you can help im trying to disable the seat belt chime but im not 100% sure what value i need to change and what to, here is a screen shot of the screen from vag com
alx_chung
Sep 11, 2006
1,538
I did this the other day for Scott. Its the top number that you see 0006401 change that to 0000401 and then hit Do It!
Alex
DanGB
Feb 12, 2006
3,772
London
I think you might have xenon lights on your car, if so, you would want to change it to 0004401. :)
AndrewJB
Aug 16, 2007
11,209
485
Maranello
Does anybody know what Measuring Block is best for logging Boost Pressure Actual versus Requested?
ive just flicked through them but couldn't see one that said actual and requested
i just got a load that said mbar Absolute
Blade
1,378
28
Teesside
You need to log channel 115:D
Blade
1,378
28
Teesside
115 Gives readings nothing to do with Boost! its like voltage or something
115 gives me this;
'115
Engine Speed Engine Load Boost Pressure Boost Pressure
(specified) (actual)
/min 0% mbar mbar
2320 86.5 2210 1110
2520 105.3 2310 1320
2760 135.3 2390 1630
3080 189.5 2440 2140
3640 191.7 2450 2660
4000 182.7 2100 2510
4160 158.6 2390 2030
4520 191.7 2540 2580
5040 191.7 2550 2780
6040 191.7 2340 2490
AndrewJB
Aug 16, 2007
11,209
485
Maranello
:( Not me
Ive flicked through Channels 0-200 and i dont see a single one that mentions Specified and Actual
using the VCS 811.2 BETA
ragz
74
activated my remote window closure
only worked once now it wont even work.
double checked the coding and still no luck
anyone got any idea what has gone wrong
someone pass me their long code so i can compare
thanx in advance
