adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Quick question, does your TIP get hit need the bottom by a black coolant pipe. The one you need to unbolt to fit the TIP? Would be interesting to see a pick if its the same as mine.
The metal pipe? if its the same pipe as on the leon you can force it past with a bit of grease but its bloody tight.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Damo, What size is the hose/where did you get it from to run a cold air feed?
As I'm sure you've already seen there is NO WHERE else to run it from and I can't be arsed to drill my headlight!
90mm hose from here..
I trimmed about 15mm off the end of the TIP so it doesn't touch anything :)
Damoegan
Oct 15, 2007
8,993
Newcastle
Damoegan
Oct 15, 2007
8,993
Newcastle
Depends on how long it takes to do the clutch, Alex...
All gaskets are fine at the mo too, just the stripped bolt hole to sort out..
