Turbo doesn't care about the HK achieved, only how much boost it runs Keep it under 1.3bar and everyone will be happy!I was close on the torque figures! Do you think the turbo will be ok running these figures Damo?
Metallic rattle might be knocking, careful!
But very nice numbers indeed!
No, it's not knocking. More likely my 7mm spanner I dropped down the back..........
Which you may find in the downpipe if you had it off I found all my lost manifold nuts and washers in there
Nah, engine cuts back, waits for problem to clear, then goes on the boost again. No CEL?I think its boost related. N75, actuator or something along those lines...
Just a quick one - but I *think* there might be something wrong with the graphs....
i would be a little worried about the flunctuation.On the test drive it was aparent that there is a magor boost problem.. Fluctuating boost quite bad. It also makes a metalic rattle between circa 4-5k RPM
