jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
Visit site
that aimed to me?
i needed to replace the crappy steel mesh one on there, and i got a nice piece of shiny blue hose so every ones a wiener
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
I went for a Green Cotton twin cone to be different :)
Gravesie-363
LCR 225
Aug 4, 2009
353
Darlington
IM gunna have a gander tonight and try to reposition it!
I didnt know they had an adaptive ECU, does seem to have got a little better, traction control doesnt kick in in 2nd now mind like it used to!
jamiebennett81
while on the topic of air feeds
As some will know, I am messing around with the air intake at the moment, but could someone explain something to me
due to the pre facelift bumpers, I am very limited to what size intake port can be fitted and the cold air feed piping
Currently the air feed is sitting at the bottom of the bumper, but about a 1/3 of it is covered as the gap is 50mm and the piping is 90mm
the next logical step is to remove the fog as the hole for this is 80mm, therefore a 30mm increase over the initial intake hole
now would there be any difference if I still run an 80mm port, but instead of running the 90mm cold air feed, I fit a 102mm cold air feed?
in essence my question is, can something only flow as much as the size of the intake allows?
I guess fitting the largest cold air feed cant do any harm though....
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
How are you going to fit 102mm beside the battery? mine is a tight fit [think its 76 or 80mm] is it just squashed to a oval?
Aug 24, 2007
800
100mm metal goes ok by the battery as long as there are no silly plastic bits left from the original feed :)
jamiebennett81
Maybe mines bigger then I seem to remember it being a bit tight, its a good fit for the foglight hole tho :)
no, yours must be 90mm mate if its tight, as mine is 90mm and its tight right now
102mm is going to be interesting to fit:cartman:
really hoping to see an increase with the g/s
Deleted member 20376
has any1 gone for the Jetex Jetex DCAF Kit or the carbon version??
jamiebennett81
The headlight cover is the only issue Tone. How flexible is that ducting ?
To describe the material its a bit like tarpauling, with a coiled wire in, giving its rigidity, but very mouldable to point in a certain direction and can be flattened. I will take a pic of it tomorrow, as that alu stuff I see on yours I have also had before, its shite, constantly cracked and was very difficult to mould to the right position
take the external plastic cover off the battery Tony, should give you enough space then.
yeah I did think of that, but it will look untidy. I may have to though, function over form
Aug 24, 2007
800
Mine is cooker hood extraction stuff, designed for harsh conditions and easy to form with a block and hammer:D So far it has lasted really well.
jamiebennett81
ah ok, different to the shite sold in Halfrauds then
