o right I thought I'd seen high 210's posted about the place, would that have been for standard LCRs then yeh?
while on the topic of air feeds
As some will know, I am messing around with the air intake at the moment, but could someone explain something to me
due to the pre facelift bumpers, I am very limited to what size intake port can be fitted and the cold air feed piping
Currently the air feed is sitting at the bottom of the bumper, but about a 1/3 of it is covered as the gap is 50mm and the piping is 90mm
the next logical step is to remove the fog as the hole for this is 80mm, therefore a 30mm increase over the initial intake hole
now would there be any difference if I still run an 80mm port, but instead of running the 90mm cold air feed, I fit a 102mm cold air feed?
in essence my question is, can something only flow as much as the size of the intake allows?
I guess fitting the largest cold air feed cant do any harm though....
Maybe mines bigger then I seem to remember it being a bit tight, its a good fit for the foglight hole tho![]()
take the external plastic cover off the battery Tony, should give you enough space then.no, yours must be 90mm mate if its tight, as mine is 90mm and its tight right now
102mm is going to be interesting to fit
really hoping to see an increase with the g/s
The headlight cover is the only issue Tone. How flexible is that ducting ?
Mine is cooker hood extraction stuff, designed for harsh conditions and easy to form with a block and hammerSo far it has lasted really well.
