Yep, popped them in today. Easy.
As it was a fine day and I thought I had time, I decided to swap my front suspension over, to replace wishbones, hub carriers and arb. Flipping cold out there!
Anyway, I figured the
problem area was likely to be track rods (as whenever they do my tracking, they seem to need to get the oxyacetalene torch out.) I started on the passenger side and after a squirt of shock-and-release, the locknut came undone pretty easily. In fact the locknut was stuck on the rod and I managed to wind the rod all the way out of the track rod end.
Lulled into a false sense of security, instead of tackling the offside track rod, I stripped the passengers side right back to strut and driveshaft. The trackrod end allen key hole disintegrated so I couldn't remove it. I hadn't bought new trackrod ends but I thought I'd get some on Monday.
I moved to the offside and the locknut on the trackrod was solid. I dug out a gas blowlamp and eventually managed to move the locknut a couple of turns on the trackrod. The trackrod wouldn't turn like the offside though. I decided to undo the trackrod end balljoint to wind it of the rod. Got the nut undone quite a way but then the allen hole gave in. I left it there. I guess I'm going to have to try a nut splitter to release the rod end fron the hun carrier.......... Ho hum.
