Iam still struggling atm, It just cannot connect to the ECU to read, keep wanting me to turn IGN off then back on again. Will carry on playing with it over the weekend and hopefully crack it!
I ran my copy on Windows XP. You shouldn't need to actually install anything other than the drivers.
If I were you I'd get the software that came with the cable working first, as this is the only one you can be reasonably sure will work. You mentioned you had installation problems, can you post any error messages or screenshots?
stupid but are you installing in x:\program files\ ?
if so try installing it in the root folder. ( c:\ )
microsuck tried to make it harder to install any programs that may have been harmfull.
You should be able to just run it straight from the disc, or failing that just copy the folder to your desktop and run it from there. There is no real need to actually "install" it.
Update:
Got Win XP on my laptop, worked straight away! Got my key code !!! Only took seconds to attach and read the ECU.
Going to have a try of the built in key learning function soon and get the new key paired to the car.
Seat Leon 110 TDI ASV.
Is that with the current program or with VWTOOL?
Does anyone know if a VCDS cable will work with this?
