Ok so the radiator top hose that goes into the engine/top of rad (with a smaller diameter tube that goes to the expansion tank) keeps coming off on the engine side, sprayed water everywhere! was scary
the radiator moves at the top for some reason, so i have tie-clipped it to the slam panel, but the other day it done the same, is it the crappy jubilee clip? is it meant to have a pinch grip clip, or a screw-driver tightening one?
as i am gonna order a new top pipe from sere motors, so if you guys can tell me what clip to get instead (it's a 2.0 16v gti)
thanks!
(and i think the main cause is the broken leg that the rad sits on coming from the slam panel, i have a new slam at home, but ain't had time to put it on, is it hard?)
thanks!
