Fitted the THS FR3 Engine Mounting System yesterday with the
help of a mate with a lift. Sorry there's no pics but I forgot to take the camera to the garage, damn. These were relatively easy to fit with access to a four point lift and I reckon we'd have really struggled without it but as it was the job was completed in about an hour. We did one mounting at a time ie removing one and then replacing it before moving onto the next.
Parts we had to remove from above the engine were Strut Brace, Airbox and Battery Cover. The Expansion Tank and Power Steering Reservoir also had to be loosened and moved out of the way and then the Splash Gaurd from under the engine. Once the Aibox is off you can take the top off of the trunking which carries part of the wiring loom, underneath the wires there are holes to gain access to the mounting bolts. We then lifted the car, positioned an axle stand underneath to support the engine and then lowered the car until we were at the correct height. The engine mount can now be removed and refitted, simples.
We then lifted the car, moved the axle stand to the other side and did the same again.
When we had fitted the top two engine mounts it was time to move onto the DBM. Because of the stiffness of the top mounts there was no need to support the engine so we just lifted the car and changed the part.
We then put back all of the parts that were removed and congratulated ourselves on a job well done. When I started the engine I was supprised how little vibration there was in the cabin, hardly noticeable at all and I reckon if you did'nt know the parts had been changed you would'nt be able to tell.
Driving the car albeit a short distance so far the first thing you notice is that the car seems much more direct in putting the power down and there is now absolutely no movement in the gear stick when you accelerate and ease off.
All in all a worthy mod and with the SCN discount it's a good price too.
