Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Standard. Ko4 down pipe just made into. 3inch think that's what he wants same as me you could make shed loads selling them . I'm not going BT I'm with T mobile lol
Feb 27, 2007
1,261
Behind Wilko
this is what i saw when i started making the downpipe on Friday.... and this is why i almost gave up without starting
ive been sorting the TIP today, i just need to drill some hole and weld in some stubs.
ive also remade my meth tank. the filler was rubbish so ive replaced it with a bigger stainless jobby and ive also had the top powder coated... ive fitted a sensor which will run in series with the washer bottle sensor, i will also be running a pipe from the rear wash pump to the tank so if it goes below min i can top it up by pulling the rear wash.
Feb 27, 2007
1,261
Behind Wilko
Don't you love it when you have things turning up, it's like Christmas :)
tomorrow should bring my ECU with a REVO base map on it and a Sachs Organic clutch and lightened flywheel
