lol cheers guys , to fit lauch control ,and wire bits up 1.20mins done
then decided to do further ripping into the engine why i havent got a decent idiol
right ive had a dam
problem with lumpy idiol , after 3days of rechecking wireing /maping it has to be a internal engine
problem , so removed the rocker cover and found this (pic upside down) ull notice the cam timing isnt algined , as i couldnt understand why as i know i algined this with a locking tool , so thought , i better do more detailed removeal
so stripped off the vvt pulleys then the rear plate and found this
a brokern piston ring on the cam? as it looks as it been digging in the vvt pulley causeing it to lock , i assume with oil pressure ,making the timing no to algin ,,
so replaced all 6 of the oil rings and re fited the vvt and vvt pulleys re timed it up and yipee , it now starts and idiols loads better ,and nic vacum at 20
loads better on afr as well
all back just a water leak to sort , and i think im about ready for round too of tuning lol
quick night shot of the caddy
