HELP vagcom not connecting
Feb 22, 2009
3,618
South Wales
cannot seem to connect my leon a 04 plate tdi cupra to central convenience 46 but the same setup is able to connect and control on mates 53 plate tdi cupra
cannot connect to control message pops up in my car but as above works fine on a 6 month older car
any ideas
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
for the obvious cant see the trees through that forrest !!
luckily didnt blow anything then , u still got the original mark , fit it in and wel have another go
also found it odd that it will connect to the engine and not the convenience 46
software is 409.1s i believe
Andrewcupra TDI
Apr 30, 2008
3,282
rather than make another post , il tag along here
while checking vag com to see my injectors cilinders 1 & 4 ran negative figures and 2 & 3 ran positive anyone know off hand why this is wernt sure what to search for in vag com section
where as marks showed very differently all being consistent mostly all positive
cars are listed at OP's first post
any one help on this
3,618
South Wales
ok guys refitted the standard aura head unit last night
Still could not connect to the option 46 :cry: - any ideas guys what else it can be?
all i want to do is turn on the alarm chirp
723
cumbria
www.facebook.com
Hi mate just found this in one of the threads by cjhawker,this could help
COMMON ISSUES
Make sure the ignition is on. Don’t have to start the engine for 90% of things
If getting comm. Errors lower the Baud Rate in the Comm port setting in windows
device manager.
If having trouble or cant connect to Address 46: Central Conv
Try removing then reinserting these fuses to restart the module (easier than
disconnecting the battery):
Number 14 - (10A) is in the manual as interior lighting, central locking/electric
windows. It also has underneath a 5A marked down for Interior light but still under
14.
Number 38 - (10A) is boot light and also central locking/electric windows.
hope it helps,i had this at the weekend,wouldn't connect,then an hr later it would:shrug:
i blame the e-bay cable tho,gonna invest in the proper one from ross-tech
Mar 26, 2007
2,020
S.Wales
Ye, I can never connect to my convenience module (too many errors). It's got to be down to the ebay cable I reckon.
Feb 22, 2009
3,618
South Wales
hmmm the cable as i said earlier connects fine to andrews car which is also a Cupra TDI but odly has not got a boot 12V supply or the lights above the sunvisor's
will try the fuses next monday though
Theresias
Just because it connects to a different car (even if its a similar model) may not indicate that its actually flawless. ;) Believe it or not, with 3rd party hardware the mentioned "too many communication errors" is a design flaw of the interface hardware used. There's a reason why our stuff uses micro-controllers and costs a little more than the cheap stuff, because we need to ensure that it works no matter what. ;)
BeartheBruce
Ross-Tech, LLC
Apr 23, 2006
527
Near Philadelphia, PA, USA
still find it strange that it works perfectly on the one leon and not the other
The control modules are very different from one platform to another. They often do not communicate at the same baud rates on the KLines. As a result, the interface must be capable of adapting to these changes. The higher priced units do this. The lower priced ones drop the circuitry which handles this change so they can give you the bargain basement price.
VAG-COM does give you the ability to tweak the baud rate to see if you can find one at which the interface will operate.
By the way, within the same vehicle, you can have modules that will communicate at one rate and others that communicate a completely different rate. It's not the diagnostic tools issue - it's the VAG group issue.
All modules using the CAN bus communicate consistently. But, VCDS for CAN only runs on genuine Ross-Tech interfaces.
Feb 22, 2009
3,618
South Wales
the two leons must have the same control modules
Theresias
Yes, the aftermarket page is still valid for vehicles using the k-line for communication.
When it comes to "must have same control modules", I wouldn't be so sure about that... even if its the same model year there is no guarantee for that. ;)
