Busy weekend....
Brakes are now fitted and bled. I have tried them with both my OEM RSTT 18's and my 17" Avus's. Both sets of wheels need spacers to clear. I have 10mm spacers on the front atm which clear fine on both but wouldn't recommend anything less for the RSTT with an ET of 33... the Avus's would need a minimum of 5mm I reckon although you could measure the gap with a feeler gauge between the spokes and the caliper and I wasn't gonna risk damaging my calipers . I have also painted out the yellow 'TVR' with matt black paint.... stealth++
The oil drain pipe issue has been solved...
Charge pipe has been modified...
Hit a few problems with the oil feed pipe, apart from it being a little too long, it doesn't have a reducer in it to limit oil flow to the turbo bearings. The Garrett GT30 I am using has a roller bearing whereas the K04 has a sleeve type bearing that uses high pressure oil to lubricate it. The roller bearing doesn't need this so a reducer is used to reduce pressure. This is currently being sorted... I also need a hole drilled and tapped in the exhaust mani to take the EGT probe that is usually fitted on the turbine housing of the K04.
Once that is all sorted, I can bolt it to the head properly and offer it into the car for clearance checks before finally bolting in the head... WooHoo!!...
more to follow....
more to follow....
