You shouldn`t need one .Mine works fine without
Your existing fakra lead fits into one of the holes ,I think its the inboard one.
I was reading on Briskoda last night about newer firmware for their machines 2660 or something and how a couple of them had bricked their RNS 510 which makes you think!! I downloaded your links last night but not unpacked them yet.
Glad you got the unit now have you managed to find out which firmware version you. To burn the disc download them, unpack the first this will unpack them all so you only need to unpack the first one. You then have to mount the disc. I have a mac and use toast to do it, it is just an option to do this and isn't hard. once it is mounted you can then burn the disc to a DVD. The .nrg is a Nero image file you you could use Nero if you a pc
Just a quick note to anyone who has fitted the RNS510 and removed the FAKRA connector from their (single) aerial and just plugged it into one of the inputs.
Purchase this adaptor directly from these people as posted earlier on.
kufatec.de/shop/product_info.php/info/p1396_VW-antenna-adapter---junction---FAKRA.html
They accept PayPal - quite expensive - but well worth it.
Makes a huge difference - you get the traffic reports almost as soon as you turn the unit on and it pulls in many more radio stations.
and remember to buy the clips with the facia, the aux pin swap and the safe pin mod.
Chris
On the voice directions do not appear to be very loud and cannot hear over the music although it does dim the music when she speaks, can i turn this up in any way?
Just turn the volume up whilst a navigation announcement is being made, the nav had a separate vol control to music etc, same with the telephone whilst you are making recieving a call (assuming you have bluetooth )
Do your nav directions come up on the MFD ok?
CLIPS?? This will be why the face plate does not fit properly on mine!!
Anyone know the part number I will need?
Thanks!
G-B
