Vacuume hoses size UPDATED
greg
Newbie
Aug 31, 2005
256
Oh, and i soaked one end of the silicon hose in boiling water for a minute or so to make it more pliable so it slips over the nipple on DV.
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
feck sake every1 was telling me 3mm and i didnt see forge recommend 4mm.
Thats why i started this thread to find out what one i really should be using as every other thread has something different.
(Shame the search didnt come up with your threads where u have said it before)
Will i get any problems then Myki running 3mm? Should i get some 4mm ordered now do you think?
I run 3mm with no problems...
As do other people i dont see the big difference that 1mm will make.?
Maybe better airflow at a push but not anything i would say you would ever notice.
Perhaps forge could come up with the answer why they recomend 4mm..??
venner
Drives Ibiza Cupra T
Apr 21, 2009
197
Near Bristol
Ok so its just a mixed view so as ive got the 3mm on there now i just aswell leave it as it is then as other people havent had problems.
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Will run fine on 3mm hoses mate but if you were to start doing more mods which were to do with boost then id grab some 4mm, an when you get a turbosmart dv id use 5mm just for the dv an 4mm the rest
venner
Apr 21, 2009
197
Near Bristol
Ok thanks for the reply, im planning to get my remap at the end of the month would u say to change upto 4mm b4 then?
Then its turbosmart time next month payday, you say use 5mm on that but that will be really huge on the end that connects to the engine bit wont it? Would i just use a mini jubilee clip to attach it?
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Ah yeh i guess it would depend on where you plumbed in the turbosmart if you use 5mm or not. 4mm will be a tight fit on the top of it an trying 3mm will rip you nails off trying to get that over the turbosmart port. Give us a shout when you get it if you need help cos im like the turbosmart king on here lol
venner
Apr 21, 2009
197
Near Bristol
Thanks Myki i had already guessed your the turbosmart king on here as have helped when ive asked other questions.
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
when i got my turbosmart valve it came with 4" long 5mm silicone hose for the top and a straight plastic reducer to fit with the rest of the system...simples..
