278bhp / 253lbft torque on std Cupra!
Al
7,331
9
Yes it does, your results arent very good at showing the difference due to the variables of the skill of the driver on the day and grip of tires due to standing starts.
Me, h8t w8p and a sean have had a few plays now from rolling, them both being mapped and me standard and they left me for dead. The difference is massive, it really really is, they went past me as if I wasnt trying.
The clips above would suggest otherwise lad. I have also seen how a remap alone car fares with a stage 2+ car, and on the road, there is not a huge difference until higher speeds are reached.
Poverty
You have gone from standard to mapped back to standard before havent you? That in itself shows how much difference the map makes.
But honestly, from 3rd gear onwards the mapped cupras left me for dead.
Blade
1,378
28
Teesside
I can put mine back to standard on the move - believe me the difference is very noticeable - in standard trim the car feels asthmatic in comparison.
benskin07
82
South Wales - Cardiff
Al
7,331
9
I have been in and driven Owens car who has the same set up as you. The best thing about his code is the valet mode which results in 40+mpg with ease! Its really cool how the car can be changed on the move, i have to say! Add that to the ability to go in to 360bhp mode within the blink of an eye, and you have a really nice product!
For what its worth, there is virtually no difference between Revo Stage 2+ and GIAC Stage 2+ from what I have seen and experienced. All things considered, the GIAC multicode option is really nice :)
Blade
1,378
28
Teesside
Well judging by the RR day i was at on Saturday it was around 35bhp;)
Blade
1,378
28
Teesside
Any details?
Code:
Name bhp torque lb/ft
Damoegan 236.9 267.3
Crafoo ------- 160 171
tzockonne 220.7 369.9
RickyD1975 278.6 253.6
Super-Electric 239.4 254.6
Danny20vt 163.1 183.9
Miss Hamilton 205.6 220.3
Lodgey ------ 223.4 221.9
DPJ ------ 301.1 261.1
Woodlehouse 192.2 190.7
RobH ------ 317.5 326.3 Revo stage 2+
Chrisboyle999 316.5 339.6 APR stage 2
RobVT ----- 177.3 232.5
Blade ------ 351.3 359 GIAC
RobVT's mate 179.3 182.4
Sooty22 ------ 190 131
1,207
Berkshire
Out of interest, regarding the rolling road figues, could it just be the case that most dynos have been configured to estimate the losses incorrectly?
For example, my LCR got 234bhp stock, and 281bhp after a remap (which I found hard to believe), so I assume it over compensates the losses for the flywheel figures.
Can I ask what wheel figures you're getting for the Mk2 Cupra, to go with the flywheel figures?
Cheers,
Rob.
Al
7,331
9
Code:
Blade ------ 351.3 349 GIAC
Rob is just running a KMD pump and Milltek TBE though isnt he? No intercooler or intake upgrade? Not sure I would be running Stage 2+ with only those mods.
What was your wheel hp figure?
RickyD1975
Audi A6 2.0TDI 170 S-Line
Jan 2, 2008
572
North East
After speaking to Rob on Saturday he's running stage 2 Revo without a intake upgrade or intercooler changes as you've mentioned above.
RickyD
rudgey
Mk2 Leon TFSI Sport '06
Jul 2, 2008
286
near Midland VW ;)
You can run revo stage2+ with just the uprated pump i'm sure i heard revo carl say once! Just can't have the settings turned up full chat! (You might also need the zorst! Can't remember exactly!!!)
EDIT: May have misread your post! It seems you may already know that!
RickyD1975
Jan 2, 2008
572
North East
Cheers,
Rob.
235bhp @ the wheels as below for a standard Cupra:-
RickyD
Al
7,331
9
It puzzles me why people would run stage 2+ without all the hardware required though especially when the likes of Revo is adjustable.
For example, if a fuel pump is added, fuelling can be increased (lower number on Revo settings).
At the end of the day, its all well and good claiming to be at "Stage 2+", but really, you are not at that level without all the bits to go with it. The figure 317bhp figure is 4bhp lower than another Cupra up this way was at with Revo Stage 1, Milltek and Carbonio.
Blade
1,378
28
Teesside
I was only winding you up djhorace:D. Its just that whenver i go up against "other" tuning companies products i come away with a significant advantage, ie, even if everyone is down on the day " dyno lottery" and all, i still make 30bhp or so more than others.I don,t have an intercooler by the way.
Here,s my map from saturday
Al
7,331
9
Not too bad mate especially if you still have OEM intercooler. I guess one give away of that is the way the torque drops quicker than print offs i have seen from cars with an uprated intercooler.
On mine, the cross over point for power and torque is about 1000rpm higher using that same scaling.
Blade
1,378
28
Teesside
Thinking about an S3 intercooler upgade but still don,t understand exactly what advantge its going to give me, considering that its used purely as a road car
Mar 29, 2007
1,207
Berkshire
RickyD
15% estimated loss then. Seems quite likely doesn't it - not bad from stock car.
The way that engines are usually rated, is the quote flywheel figure is the average (not sure if it's mean or median) based on allowed tolerances, so for all you guys getting better figures there must be others getting lower figures?
Unless VAG are different to everyone else and decided to quote the lowest allowed output...
