1st ok i understand where your coming from but like poverty says revo ran there k1 with the exact same mods as me for a fair while and not everyone can afford to blow £2.5k on all the mods required straight away.
2nd you carnt adjust the fuel settings on revo until you get revo stage 2+ code hence why i got it.
3rd i know it isnt fully stage 2+ yet (intake is in the post) and my car wasnt running too good either with the poof of black smoke around 5000rpms which needs logging on vagcom but point taken dj .
im glad i put on the rollers as somethings not quite right whopfully we can have a better comparison next time round blade with all the hardware to go with stage 2+ and the smoke problem solved.
Not wanting to be picky about it but I was not aware that Revo ran stage 2+ code with just a pump and exhaust.
The purpose of stage 2+ is to take advantage of the fuel pump, but you can increase the fuel settings on a Revo car by way of making the fuel number smaller. I know this because I know of a car that ran all the stage 2+ modifications on stage 1 code, and another with all the mods and stage 2 code.
A car with all the mods for Stage 2+ (pump, exhaust, intake, intercooler) can run stage 2+ at fuel 9 with no issues. Therefore, if you are running Stage 2+ code with a stock intake or uprated panel filter or carbonio type thing, the car will be running pretty rich as the intake is really restrictive.
You will find that your numbers will increase with an uprated intake though Rob as the intake should give as much gain as a Turbo Back Exhaust.
