Thanks for the great guide - I did my rear doors the weekend. I went down the slightly costlier seal from SEAT, but one strip did both rear doors with some to spare. Mind you I only did the bottom and half way up the sides with the new seal, from that point I left the existing seal as it seemed unperished.
Should chuck it down over the next few days so I'll find out if it worked.
OK maybe someone can help me i have a stinking water leak in my mk3 ibiza and its not coming from the doors but it does run straight down my accelerator cable and soak my feet every time i drive (infuriating) taken it to a garage several times and they are telling me that they cannot find the leak anywhere, i think that they are just not trying hard enough as i have told them exactly where it is coming from.
I put my hand up under the dash and alot of the water in pooling in the plastic behind the fuse box! does anyone have any good suggestions as to where to look and what to seal!
Me and the ibiza are not having a good time drivers side window has broken and a badger committed suicide on the m6 using my front bumper and AC grille i think the car looked more battered that the badger.
Cheers for the help
I have this problem to on the passengers footwell its fully of water.I am not to good with diy to do this on my seat lean cupra tdi 04.does anybody know of any good garage who could fix this water leek for me.must be around the manchester area swinton or salford, if anyone can help me out would be much appreciated.
