If you want max g/s then go for a metal guaze filter rather than a cotton one but filtration isnt as good.
Probee have you seen the Dynatwist XXL considering we are using only the XL version, its rated 100 bhp higher than the XL so must flow better too.
Forgive my lack of knowledge but surely its not all about air flow but the temperature of the air going in the car? No good have lots of air flow if its hot air?
I think this is why Probee hit the jackpot because of his twin cold air feeds from the fog lights feeding his modified dynatwist. Only problem i got with the dynatwist design is the metal used...surely thats a magnet for heat?
Sunday 14 June 2009 17:38:09
1ML 906 032 A 1.8l R4/5VT 01 0001
Group A: '066 Group B: '115
Speed Bin. Bits Bin. Bits RPM Load Absolute Pres. Absolute Pres.
TIME TIME
MARKER STAMP km/h STAMP /min % mbar mbar
15.88 48 0 0 16.3 3560 91.7 2450 1180
16.7 52 0 0 17.1 4440 191.7 2550 2540
17.5 66 0 0 17.9 5520 191.7 2440 2320
18.3 81 0 0 18.7 6280 182 2320 2260
19.12 92 0 0 19.52 6960 160.9 2290 2260
19.93 101 100 0 20.33 6280 13.5 990 1330
91.92 44 0 0 92.32 3760 182 2530 2220
92.74 56 0 0 93.14 5240 191.7 2540 2490
93.54 75 0 0 93.94 5760 191.7 2410 2230
94.34 85 0 0 94.74 6480 191.7 2300 2170
95.14 95 0 0 95.55 5800 115.8 2230 1470
95.95 101 0 0 96.35 5320 191.7 2460 2370
96.75 110 0 0 97.15 5760 191.7 2390 2430
97.55 119 0 0 97.95 6120 191 2330 2300
98.37 127 0 0 98.77 6440 182.7 2290 2250
99.17 134 0 0 99.58 6800 45.1 1000 2540
99.97 139 0 0 100.37 5400 186.5 2440 2250
100.78 144 0 0 101.18 5680 191.7 2410 2400
101.58 150 0 0 101.98 5880 191.7 2380 2340
102.38 156 0 0 102.78 6080 191.7 2350 2320
Group A: '002 Group B: '118 Group C: Not Running
RPM Load Inj. On Time Mass Flow RPM Temperature Load Absolute Pres.
TIME TIME TIME
MARKER STAMP /min % ms g/s STAMP /min °C % mbar STAMP
58.91 3040 88.7 7.14 53.08 58.51 2920 39 0 1330
59.7 3400 124.1 10.88 100.5 59.3 3200 38 19.2 1360
60.52 3960 191.7 18.36 168.47 60.1 3640 38 85.5 2310
61.32 4520 191.7 18.02 184.25 60.92 4280 37 85.9 2530
62.12 5040 191.7 17.34 204.06 61.72 4800 37 85.5 2480
62.94 5520 191.7 17.68 216.36 62.52 5280 37 87.5 2410
63.74 5960 191.7 15.98 223.33 63.34 5760 39 90.2 2350
64.54 6320 191.7 15.3 227.94 64.14 6160 39 89.8 2320
65.34 6640 175.2 14.62 231.19 64.95 6520 42 89.8 2250
66.15 6800 121.1 7.82 222.61 65.75 6840 44 89.4 2220
66.95 5480 137.6 15.3 179.78 66.55 6400 44 0 1350
This is what I'm thinking too.Well done chaps, as said well deserved!
On another note, going back to the modified heat shield absorbing heat due to being metal... I have the carbon bmc... you can see where I'm going with this... is it worth modifying this in a similar way?? Not sure if I could plant a different filter in there easily though??
Even two feeds to this, one to the side and one in the conventional method
