Hell Yeah...
If your just slightly on the gas between changes(normal driving) it will cut the ignition and come back on(quick enough so you can feel it)..So your foot has to be all the way off wen changing as if it detects uve wot shifted and not changed quick enough it will cut it for a breif moment..
But if uve got the Throttle on 80% and quickly dip the clutch jesus the spit you get out of the exhaust it loud ive never heard anything like it....then Followed by a flame
On gear changes i was seeing 14psi on changes instead of 0psi so it was a monster once spooled up...
I 1st started it off at 250ms On changes but it was too slow Normal gearbox changes is near 450ms(human shifting)...So mines set @ 170ms now and its just right...
you can tell when you've sped up the wot shift to fast as it will crunch wen goin in to gear (When WOT Shifting)So id start at 250ms and work you way down to how you want it...
now the launch control is real fun but you cant have it on for long 5 seconds maxiums as it will detect a Missfire and go in to Gimp mode..The launch controls set @ 3500rpm and is at 7psi on the gauge instead of -0 vac..so once your off the line you on the power kinda instanly..
Another thing that took me a while to get used to ingaugeing the launch control at the light as the clucth and Throttle have to be pressed very quickly at the same time to activate the launch..U'd know your self as you can see it blinking but be warned...Ive never known a Blue LED to be so god damn bright so mines in the cuddy hole out of the way.
Normally when the lights are just changing But it does take alot of experiance...But its a Awesome peice of kit for £140...
Its in no way means a anti-lag but defo keeps you on the power once going...
Give it a few Weeks of driving with it all setup then you will get the hang of it..I did
