ive read loads tonight on this, lots of post about WMI killing TB's but mine is only running rough on idle, its rapid otherwise but running very rich (im guessing as it pops and farts)
Worth putting the pipes back on...?? Kept mine on with a pressure still feeding in and no problems tried without and ran like a bag of poo. N249's have been known to throw up weird faults! :)
Pop and farting could also be to much air.... :) EDIT (which of course would cause it to run rich.....yes I'm special I know!!! ;) )
Checked for any obvious boost leaks? If there was a leak sucking in air and causing the car to overfuel would the MAF not go ape trying to compensate for it?? If its of any help I got a boost leak tester??
after lots of playing i finally managed to get the TB to adapt. its now idling fine.
something obviously went a bit weird for a minute there but it now seems fines......fingers crossed.
possibly...actually yes.
i had another terrible drive home
VAG-COM Version: Release 311.2-N
aary
Control Module Part Number: 1ML 906 032 A
Component and/or Version: 1.8l R4/5VT 01 0001
Software Coding: 10510
Work Shop Code: WSC 78646
Additional Info: VSSZZZ1MZ4R101117 SEZ7Z0D2450074
4 Faults Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
16891 - Idle Control System RPM Higher than Expected.
P0507 - 35-10 - - - Intermittent
17976 - Throttle Actuator (J338): Mechanical Failure
P1568 - 35-10 - - - Intermittent
aary
1 Fault Found:
18012 - Internal Control Module Driver Error
P1604 - 35-00 - -
:) car is sorted... The throttle body was totally naffed.
Greg @ totalvag has lent me a TB until my new one arrives on saturdayish
Totalvag have always been extremely helpful, I can't say enough good things about them. It's so nice to have a tuning company like that on your doorstep. Thanks Greg
Yup - I have nothing but good words to say about them, people and attitude, prices and service are all spot on :)
Your alloy wheels colour
:yes:Really liking your LCR especially the colour of your bbs ch wheels did you get them powdercoated if so can you plz tell me what colour you got them done in as i want to get my lcr standard wheels done in the same colour free bump
