jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Your the one who purchased them from him! What a bargain that was - your wheels going up for sale?
Feb 27, 2007
1,261
Behind Wilko
You have to be quick Maz :)
They are going the same colour as the BBS were... I had them matched before I swapped them
Twin CIA's DK although nicks sounds good with one
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
Rather than having one CIA, you have 2 running in to one then in to the induction kit, Iv had the stuff to put my other side on for about a year... Might do it soon hehe!! Like Aaron said, sounds very good with only one, alltho im using a alli CIA so it echos well. There is a vid of mine that we took at the same time, when Aaron gets round to uploading it!!
paul-murphys
efr 6758 here i come
So.... i couldnt think of anything better to do with myself on the freezing cold nights and days recently.. except play in my boot.
and slow the car down..
and make room for the tank up front
hi mate im doing this tomorro. got starter motor cable. did you just take one wire from where battery was an connect the earth th the floor in the boot? im putting mine to side as i need my spare wheel.where did you run the cable? your car looks really nice by the way. gives me more ideas of what to spend money on :D
Feb 27, 2007
1,261
Behind Wilko
Best to make a new earth cable and connect it from the engine to the original vehicle earth (under the battery) then just connect from the battery earth to the chassis earth in nearside of the boot (under the carpets)
Then run your positive down the car (under the trim on nearside is good) and to a junction box under the bonnet
1,261
Behind Wilko
so it runs through the inside of the car? an i put the earth onto boot metel. you ever had any problems? thanks
Yes inside and yes I've had problems... Make sure you find the earth stud on the nearside wing
Sorry to go on about it Aaron but where did you get the joiners and metal tips etc for the twin CIA? Self made lol?
Allo matey, there's a thread somewhere with all the info on (started by myself) but the business end are some 90 degree stainless elbows which will be hardish to find
Feb 27, 2007
1,261
Behind Wilko
It was time for a change mate and the next step on the Leon was going to be expensive (better spent on an S3)
Keeping the Leon and looking at BT kits is actually saving me money :)
Feb 27, 2007
1,261
Behind Wilko
just tying up a few loose ends....
ive got to the bottom of my CF problem (well a good reason why they are there anyway), i always thought there must be a small problem that hadnt shown its head yet. my cam chain has stretched or the tensioner is giving up the ghost. im assuming this would change the cam timing enough for me to have to pull back the timing because of Cf's
also with the MAF im now at about 72.8mm and im still well over on the flow. i will keep going up in size until i can match flow to afr.
log below
Code:
	Group A:	'003				Group B:	'020
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
	361.67	3080	9.39	6.7	24	361.27	0	0	0	0
	362.48	3120	48.69	25.9	27.8	362.07	0	0	0	0
	363.28	3240	60.97	27.8	30.8	362.88	0	0	0	0
	364.08	3400	70.81	32.5	30.8	363.68	0	0	0	0
	364.88	3600	165.69	100	14.3	364.48	0	0	0	0
	365.7	3960	167.89	100	11.3	365.3	0	0	0	0
	366.5	4320	182.33	100	12	366.1	0	0	0	0
	367.3	4680	193.14	100	12	366.9	0	0	0	0
	368.11	5000	210.39	100	12.8	367.71	0	3	0	0
	368.91	5280	221.58	100	9.8	368.51	0	3	0	3
	369.71	5520	226.14	100	12	369.31	0	3	0	3
	370.53	5760	228.28	100	12	370.11	0	2.3	0	2.3
	371.33	6000	228.67	100	12	370.93	0	2.3	0	2.3
	372.13	6200	235	99.2	12	371.73	0	1.5	0	2.3
	372.95	6400	236.86	99.6	12	372.53	0	0	0	0.8
	373.75	6560	232.64	99.6	9	373.35	0	0	0	0.8
