Maybe Loosing Boost
Mat
Came a different way home from work today, and as I got near home, I was on a back road with footdown. Dunno what made me look at the bost gauge, but I noticed it was at 15psi and wouldn't go up. So changed gears (both up and down) and still didn't go above 15psi....
Only just noticed this, but I'm sure it was ok on way to pod on Sunday as I had fun on the way ;)
Usually will boost right up to 25psi.
Also, service light is on. Had crossed my mind if there was a "safe/service" mode, but realised that the light has been on for just over a week....
Can't physically hear any leaks (any hissing etc), turbo and spooling sounds all ok. The EML hasn't popped up.
May go test it tonight or 2moz on my way out
Suggestions?
Mat
felt quick yeah.... always been that high TBH! K03 with CC Stage1
Nov 10, 2004
1,000
Colchester, Essex
Blimey thats high! Bet it's pretty quick!
I guess if no codes are coming up, check connections to the boost gauge, check the t-piece.
I'd say N75, but it'd be quite noticeable, same with a MAF fault, even if they didn't post up an EML, the car would feel sluggish.
Limp mode would be very low psi
Mat
Mmmm.... now you mention it, i took the T-Piece out last week to paint the exposed bit red. Best check that really
arron2004
Cupra Boy
Mar 1, 2007
903
Nottingham J25 M1
where is the best place to pick up a N75 over the web ?
Mat
bloody wont! had to use a different filling station. Also caught attention of new under cover fuzz car! lost them in traffic, and then later noticed was low on boost LMAO
Mat
Right then, just been out and checked the T piece. All is ok.
Went for a drive, heated up fairly quickly (think I need more coolant :D). Booted it in 3rd, at around 3-3.5k it peaked to 15-16max then dropped at around 4k (not normal). Did same in 5th, but proper lost boost, rapid loss.
Pulled over, looked at bay, pushed and nuged this that and other and I think I found the problem.
Heard a small "hissss" from back on engine. Nudged tip near air filter and it changed to more of a hiss. Nudged along various parts, near DV etc and gets louder around there. Wont boost about 5psi now lol. Guess I know what I have to do 2moz (luckily my day off). Check all clips and connections!
I hate cars [:@]
:cartman:
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
you know you love em!!!:D whats the difference with n75j valve to the normal one?
J will most likely cause problems.
however some people have luck with them and get slightly more boost.
I guess if you're willing to spend money on something that might very well cause problems, then feel free.
If not get the regular one
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
oh and mat, what do you mean with the 'service light'?
we have one of those, indicating the car needs to be serviced?
I do my own servicing and have had the car for over a year and a half, and never seen such a light?
Nov 10, 2004
1,000
Colchester, Essex
Ah, well it doesn't sound too bad a problem mate, just a loose connection somewhere, check the dump valve is seated properly with all 3 connections tightly secured.
Also check the pipes coming off the boost pipe to the N75. There are 3 pipes going into the N75, check both ends are connected tightly.
Might be the top vacuum off the dump valve.
Cuprachrissy> The N75 'J' valve is meant to boost a little higher than the standard C or F valves. I had a C valve on mine, before it went wrong, so just replaced it to a J valve, runs lovely!
cuprachrissy
ok nice one, what vac pipes go where on the n75 valve bud? my car is off the road and i just changed turbo, etc. removed all my vac pipes too so dont know where they go back :help:
Mat
yes Dutch man, the service indicator that comes up on ignition where it shows mileage. Me and a mate will be doin a service on it soon
Nov 10, 2004
1,000
Colchester, Essex
Hi mate,
Well if you have a forge TIP, one part (the longest part) of the N75 goes into the side of that, the other part comes from the boost pipe to the bottom part of the N75, and the other one goes from a vacuum pipe leading down to the turbo/actuator area (into the left of the N75).
