Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Standard shifter bracket
You can see where the back of the pin has been rivited over to stop it coming out. I ground it back a few mm so that I could knock the pin out with a punch.
Like this.
Pin out.
Drilled and tapped the pin.
New pin position.
Original Vs short shifter
Damoegan
Oct 15, 2007
8,993
Newcastle
Looks wicked, how hard was it to do? What tools are needed mate
Very easy to do if you have the skills.
Tools used:
Grinder with flapping wheel to grind the back off the pin.
Hammer and punch to knock the pin out.
8mm drill to re drill the new hole.
Drill and tap set (4.2mm drill and M5 tap set)(I used a center lathe to when drilling to keep everything straight).
M5x10mm button head bolt and spring washer (pluss some loctite).
Hope this helps mate :)
Damoegan
Oct 15, 2007
8,993
Newcastle
Nice mate have you had it on yet?? hows it feel??
Yea, its on mate. Fitted it straight after I made it :)
It feels good but I think I will do some adjustment with it as I feel the 40% reduction is a little too much. I'm going to make it to about 20% reduction when I'm back at work through the week.
May 29, 2008
675
Aberdeenshire
need some help!!! i think i might of made a bit of a c**k up when fitting the front shocks!!:redface:
you have the top mount bearing....does anything sit below that for the spring to sit on??
Sorry for hi-jacking.....got a better description in my thread!!
Damoegan
Oct 15, 2007
8,993
Newcastle
No, topmount bearings sit on top of the springs mate.
Damoegan
Oct 15, 2007
8,993
Newcastle
Made another hole in the shifter bracket as I think the reduction (~-40%) was a little too much, so its now about -25% reduction and the feel of the shift is totaly OEM too :D
PH1L NI
Agnew SEAT
Jan 6, 2009
290
Northern Ireland
www.modmedia.co.uk
Just read all 28 pages... My eyes hurt.
Just thought I'd say thanks for the link you posted months and months and months ago for the wee tiny aerial, did a bit of searching from that and got one from eBay there now!
Thanks!
Lovely car.
