Gearbox Time again -:(
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Summers finally here so time to change my gearbox again it seems :)
yr#1 original CDA went back in when i rebuilt the engine but due to helping hands the driveshaft washer plates were left off meanign shaft come loose and cracked the housing
yr#2 removed/stripped/welded above to keep her going while i found one and even on stripdown the gearchange all worn but you know what its like when you need em on the road
yr#3 Finally got sick of a sloppy stick so changed to a mk3 Tdi ASD gearbox with a sweet gearchange and a chance to try out some seriously long tdi ratios - lol
yr#4 ASD box has been grumbling a few months (mainshaft noise+diff breaking up) so finally decided it's time for to change it before it breaks (makes a change) as i reckon it wont last long
3 years / 5k miles / 3 gearboxes and yes i am putting oil in em as i have been draining and checking em every 6 mths
So purely by chance i rang a mate at local breakers i used to work at to see if they had anyhting that would 'fit' to keep me mobile be it gt/tdi whatever there is as the ratios are no bother too me either way and low and behold he's got a 34k mile CDA standard box in stock :):) bargain @ £55 inc vat
now i know what i'm doing when i'm off next week :p
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Lets hope this one lasts! :)
me too to be honest, wouldnt mind so much if i ragged the living daylights out the damn thing because i would expect it to fail then but it gets the miss daisy treatment unless i find a loooong clear road, i guess this thing is just cursed-lol
i reversed into work earlier and the whole front end shimmied across as the diff wound over so i better get her done soon before it all falls out lol
when i broke the casing (shaft broke off) i had been doing 60 down the dual carraigeway moments before so i can't be too mad with it - lol
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
lol i asked for that one
given it a treat tonight with a full frontal set of JBL speakers to which i got a quick sweet blast round the lanes in return :):)
all it needs is a blower now
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
I'm well practised now but it isn't a huge job - awkward without a ramp i would guess but not impossible
check the linkages at the top of the box first before you mess with the cables as that's where the play usually starts
OllieL
2.0 16v Cupra Sport GTi
Dec 10, 2006
1,868
Birmingham
Ha sounds like the click I'm developing behind my clocks on my dash, the faster I go the quicker it gets!
Ollie
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ye all 3 are :) in fact the box in there at the moment changes gear and select sweet but the bearings and diff groan worse than my mrs
i'll be swapping it out next thurs/fri so if you want the old one for bits ya welcome to it if it helps ?
i have one already out (original) but the change mech in that one sucked worse than a fiat
'tis a bit of a jigsaw puzzle mind :):)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Blimey Flap, I think billo had a better record than that when he was just on the first phase of IHI
No rest for the wicked - it's revenge for me leaving it lying around 6mnths every year i guess - lol
as i had planned front speakers and trim sorting for my week off i fitted them tonight instead as a peace offering to the damn thing, meant to be chopping up the rod chassis so that will probably fall on my foot tomorrow now :headhurt:
i do wish/wonder wether all those years ago i should have just stuck a 20vt in it
GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
that would be great many thanks, as said just need this part, its very badly worn on the Ibiza, I think that is why the changes on it are not the best.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
was same on my original box - right pain
current one seems ok so roll on next weekend it should be out ready
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
all sorted thurs am (sorry been away the weekend) having done it so many damn times now it's getting easier
couple of tips i found to make it easier (for me)
remove the long bar that goes down the ns to the engine mount also makes life easier removing clutch cable
undo small rear mount (3 bolts) but leave lower bolt in loose (wont pull out in situ) until ready to go
take off os drive flange (allen bolt in middle)
once that and all the usual was done i levered it out off the dowels, spun the back up (to release last bolt on mount) turned back down so diff downwards and lifted off
sorted
