cleaned my throttle body today, and noticed the pipe that goes from the top of the radiator to the engine (with a small pipe that comes from the coolant tank/water bottle) is slightly leaking onto the breather pipe (i think its called, the pipe under the pipe thats leaking)!
its at the end that goes into the engine, does anyone know the name/part number of this?
my water has gone down by about 2cm's in the last 3months but couldn't find the cause, i thought it might have been the radiator!
which pipe do you mean
hurrm....i may purchase a TB off the net or pop down the scrapy and grab a spare one to have a mess with it.
I know dinkydave has modified his by filing down bits and bobs on it.
do you spray the carb cleaner when the car is off or while its running ?
