Also mate i really think you need to get a cold side kit.. Just fills that gap in the bay.. Also you need to decide what ur doing about ur inlet and charger.. im about a week sat if you wana do them....
i cant fit it now i have my nozzle there.. im quite happy with my charge pipe and mani for now.. thanks for offering though [B)]
O yeh of couse.. Sill of me really. but surely you can cut up the cold side kit. See how mine goes together..
Ok mate. well let me know when/if. Going to be redoinf my inlet mani next weekend.
Thanks for the link Dave :)
I think that any fuel tweaks you make other than warm up ones will just adapt out (fairly quickly).
cf's without wmi are ok for the occasional >6 when the cars hot, and 3-6s when cool, but if you run wmi, if you limit it to 3's, when the wmi fails (which it will) the knock sensors have enough headroom left to save you from disaster.
Water slows down the flame front speed, so you can ignite the charge earlier without the max pressure rise occurring too early (before the piston is travelling down), and get more of the pressure rise over before the exhaust valves open. It also increases charge density (mass) so there is more mass expanding and pushing against the piston.
Maximum power is achieved if when you take the absolute maximum expansion (and consequently temperature) out of the charge. Low egts=max efficiency from charge. When you ramp up charge density, and rpm, the time available for the charge to burn/expand is reduced, egt's climb, efficiency drops. The sooner you can ignite the charge without knock, the more power can be extracted on the expansion stroke.
Cooling the intake charge has the same effect (intercooling), so wmi can be win win.
The third benefit is that the meth is additional fuel (v high octane) which needs twice as much air to burn, and messes with lambda measurement a little, but at 5% addition will not do any harm, and gives a good octane improvement.
Fueling is generally over rich to provide charge cooling where inter cooling is insufficient. Max power will be made somewhere in the 12.5-13:1 region, but most over fuel to provide charge cooling when turbos and their inter coolers are pushed too hard. That's the beauty of wmi, no need for over rich (power sapping) af ratios.
hehe :clap:
so no point in fuel tweaks then John? where to go from here then. if i need to push timing to burn the meth is my timing advanced enough to do it?
This is the part from that link that sums it up
"pressure and temperature are strongly linked, knock can also be attenuated by controlling peak combustion chamber temperatures at the engineering level by compression ratio reduction, exhaust gas recirculation, appropriate calibration of the engine's ignition timing schedule, and careful design of the engine's combustion chambers and cooling system. As an aftermarket solution, a water injection system can be employed to reduce combustion chamber peak temperatures and thus suppress detonation."
Is there any point in running the larger MAF tube here?
i was thinking the same earlier.... well i was wondering if i can make a sleeve up to make it standard again.
i didnt buy it because it was bigger, it was a bling thing :redface:
im not sure what to do Dave, it does run good power with it so do i need to change it .. i do want to be able to push the timing more.... will a standard one do that though?
I'm thinking the tube is helping you make good numbers by making Revo a tad leaner......
Move on with the wmi, bearing in mind - as John says - what happens if the wmi fails....
have a look at this log from last night Dave. with WMI running B7 T8 as the last log i posted.
its pretty much running on the rich side of requested all the time.
Code:
Sunday	8	March	2009	20:25:12
1ML 906 032 A  		1.8l R4/5VT      03 0001
	Group A:	'031				Group B:	'115
		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME
MARKER	STAMP					STAMP	 /min	%	 mbar	 mbar
	24.56	0.961	1	        	        	24.14	2240	31.6	980	990
	25.36	0.992	1	        	        	24.96	2440	54.1	990	1100
	26.15	0.953	1	        	        	25.75	2880	86.5	1500	1330
	26.95	0.93	0.961	        	        	26.55	3520	109.8	1910	1490
	27.77	0.86	0.883	        	        	27.37	4560	173.7	2390	2480
	28.57	0.86	0.86	        	        	28.17	5640	172.2	2280	2310
	29.37	0.883	0.922	        	        	28.99	6360	148.9	2230	2270
	30.19	0.914	0.883	        	        	29.77	4680	99.2	2250	1470
	30.99	0.875	0.867	        	        	30.59	5240	175.2	2320	2350
	31.79	0.836	0.86	        	        	31.39	5720	168.4	2270	2270
	32.59	0.844	0.86	        	        	32.19	6160	150.4	2220	2280
	33.4	0.75	0.93	        	        	33	6520	148.9	980	2160
	34.2	0.844	0.875	        	        	33.8	5200	144.4	2240	2110
	35	0.867	0.86	        	        	34.6	5480	165.4	2280	2350
i am happy to carry on logging and pushing it. if it breaks i have a second car..... lol it is a peugeot though so im not sure how long i could drive that around for.
Sorry for asking all the Noob Questions. Buy when the engine has to "CF" whats it actualy doing?
And a big repaire bill.. Dont forget why you bought WMI in the first place mate! To have a safer engine.. I know you got the bug.. but done push it to much or you might regret it.
Also what i dont understand is why i can run 9-9 and u cant? and you have WMI? Even with WMI off wasent you getting alot of CF's?
i'd play with injection rates and mixtures to see which improves timing the most.
Don't take injection rates off manufacturers charts. Measure them yourself. Nozzle into measuring jug for 30secs should be accurate enough.
Take your peak fuel flow and try to get 10% water, or 15% w/m.
Keep increasing rates until you see no improvement in knock suppression.
This is all a long winded exercise so you could just stick to the injection rates above. They have been found to work by aquamist, and may not be optimal for every engine, but they shouldn't be far out.
Don't spend too much time on it though. Is it worth running too close to the edge for 5hp. Go drive the thing and try not to loose your licence.
And dave an over size maf tube when your ecu has not been calibrated for it is not the best idea. You may be lucky and accidentally cause some minor gains, but it could just as easily be detrimental.
we are all hampered by our over sensitive knock sensors, or rather the ecu's reactions on seeing it. The speed at which the timing is pulled back on seeing potential knock can be slowed down, but I doubt you'll get a tuner to do it for you. You get what timing the knck sensors will allow, not much you can do without going aftermarket ecu.
its pulling the timing back to safer levels to reduce knock....
i think
thanks for the advice John, ill get the mrs's jugs out at the weekend :)
youre making me think i should be making a sleeve to reduce the ID now.
Got ya. So the less CF the more you can advance the timing. Again.. dont see why you cant run 9 timeing aaron? Strange.. So how does the engine detect Knock?
Got ya. So the less CF the more you can advance the timing. Again.. dont see why you cant run 9 timeing aaron? Strange.. I think we need another beer and food so you can explain it all to me :)
I also still have a hissing on full boost.. :ban:
beer sounds good but not sure im the man to talk to about things like this.
i have my car booked in at TotalVag on Friday for a leak check.... very cheap mate, gets yours done too?
Code:
	Engine Speed	Mass Air Flow	Throttle Valve Angle	Ignition		Timing Retardation	Timing Retardation	Timing Retardation	Timing Retardation
TIME	(G28)	(G70)		Timing Angle	TIME	Cylinder 1	Cylinder 2	Cylinder 3	Cylinder 4
STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW
497.72	4760	200.02	100	23.3	497.42	0	0	0	0
498.34	5120	231.04	100	15	498.02	0	0	0	0
498.93	5440	268.70	100	14.3	498.63	0	0	0	0
499.53	5840	296.12	100	16.5	499.23	0	0	0	0
500.14	6160	312.92	100	21.8	499.83	0	0	0	0
500.74	6520	322.37	100	18.8	500.44	0	0	0	0
501.35	6840	328.31	100	23.3	501.04	0	0	0	0
501.95	7200	324.54	100	20.3	501.65	0	0	0	0
502.56	7480	330.25	100	27	502.26	0	0	0	0
503.16	7760	327.69	100	27	502.87	0	0	0	0
one of mine for comparison:D
There are two knock sensors bolted to the block just below the inlet manifold. They are like microphones and are tuned to the frequency of the ping from knock. They have to be torqued correctly to work properly.
