So..... all in, i should shut up and be happy?![]()
If my sums are correct then with your corrected g/s readings your pushing closer to 300bhp than 280bhp so yea I'd be happy!![]()
How can you work all that out?![]()
So the actual point of a rolling road is ......... shame diesels don't spit the same information to the log files![]()
Rolling Roads give accurate results (with the exception of the dyno lottery) these are only rough figures.....
John/Dave how does this effect the load figures from block 114?
My guess*......
At 4200 rpm 191.7% 203% 187.2%
It wants to meet a load of 191.7% but it knows it's running leaner than it wants to, so it's tweaking the requested load to 203% to compensate. It doesn't meet that tweaked load, only managing 187.2% because it doesnt deliver the extra air it thinks it needs because that would mean going outside the boost parameters....?
*John'll be along with the real answer soon.![]()
I'm not absolutaely certain how actual load is calculated, but I guess maf is the greatest proportion of it, but it takes boost, air and water temp, into account, so a slightly dodgy maf reading should jsut give a bit more boost and airflow to bring the caclulated actual load back into line.
