that looks like it should stick to the road like s**t to a blanket
well impressed
Yep ive got the same setup mate and it really is quite good
Im now thinking Forge Rear Strut aswell
You do need the shorter droplinks too mate. I measured them againset standard ones and they are ~100mm shorter. If you order before 12pm from DPM Damian will prob get them to you the next day
Make sure you get some new topmount bearings too mate. I did and I'm glad I did. The ones I removed had done ~36k and were at the end of they life. Got them from David@SERE Motors off here at about £8 each http://www.seatcupra.net/forums/forumdisplay.php?f=249.
Not sure if the droplinks would fit any other setup mate, it could do though.
If your scared of springs then get some new top mounts too (there only £20 delivered for a set from SERE Motors), then you just put everything togeather first then you just drop old out and slid new in.
The rears are very easy to do, prob only 45 mins and no spring clamps neaded.
Well the plan i was going to work on the rear shock and my mate was going to do the fronts. (being a mechanic he better not be scared of springs)
Think im just going to go for the V-max ones like you have got! cheers again... will update my readers ride once i get them ordered!!
