just got to find which wire(s) are messing about now.. and fix em.. somehow.
its unwound more now, just such a b'stad to get in there and see anything with req'd pipes on it to get it running at all. getting there.
horrible job..
have you fixed bennys car yet??? i taken mine to a tunning compney that is my gf dad mate son where we checke the wiring ect tryied 3 tb and we think is the ecu but its hard because i dont know what to do if itd the ecu as its 6K0 906 032 ab (cupra R) ecu not the 6K0 906 032 aa found on cupras
Yup everything was fine on the way home(45 miles), cant thank Bill enough.
Turned out to be a dodgey connection on the main plug to the wiring loom as i understood it. Im sure Bill is able to explain better.
Just glad its fixed now i can start making the for sale ad`s!
Thanks again Bill!
I was thinking last night Bill when you mentioned about the water trap, could that not have been water but electrical cleaner(IPA)? Myself and the mechanic before you had sprayed abit in there previous.
no, that would flash off, this sat there for a few days and still appeared. heatgun used to evaporate it off in the end after much spraying with brake cleaner to drive out the water and all that dielectric grease.
