Well abit of an update after spending alittle time on it today.
I undone the earthing wires from down by the battery and and on the bell housing and gave them a good clean up ith some hemry paper and made sure they went back on tight.
The next bit is what socked me a little, when i seperated the main plug on the engine loom under the TB there was a nice little puddle of what looked like WATER! I`ve dried that out with a hairdryer and sprayed some damp start in there for now, when i get in tommrow im going to try and clean the pins with a small blade and contact cleaner as there was abit of corrosion on them.
The car now doesnt idle to bad bit is still a little lumpy, i managed to drive it around the block a couple of times and then home (approx 7miles) without any lights coming or losing revs. Thing is now, i think it needs the TB to be aligned to maybe sort the lumpy idle but all im getting now is error when trying to adapt.
The only code that comes back now is the - adaptation not started.
Also had somthing like - control module drive error, although this cleared and didnt come back.
Could it be possible that the water in the plug could have shorted out the TB causing it not to work any more? There for busted the two i have?
