on my BSR remap the yellow spring didn't hold the boost when it peaked. Could see it on my boost gauge it was fluctuating. With the blue one it was nice and smooth. My car is peaking about 23psi... ish.
let me also add: the blue spring opens as early as 5psi. So its defo not to stiff :)
so with the forge 007p d.v will i get a nice sound without adding air filters. Will be doing that in the future but skint at mo, spent last dollars on valve :)
I finally got my forge 007 fitted today, and after taking the car out on a drive its like driving a different car, no longer get that chavy whoos sound everytime i change gear. The car know longer hesitates either, power delievely is ahell of alot smoother, and all the fault codes have disappeared from the ECU. So role on the new year when i wil be getting the car remapped by either Revo or Custom Code:)
i think the issues with some turbos tend to be back pressure from a stiff dv. maybe wrong but pretty sure it puts strain on the spindle causing side to side movment. this may only relate to ihi tubbys.
d.v came in post on saturday but as i was hungover to the max i wasnt in shape for doing it ha. I put it on this morning, you guys were right, took me 15 mins max.
ie please :happy:
Hi
I hope that your feeling better now
Hungover , nice one :cartman: it is the season
Sarah
i felt like crap, went to see stereophonics in newcastle on the friday and out round newcastle after gig. Was still drunk when woke up which is always fun ha
Which DV did you have on before?
I've got the SPLT R valve, been on for 3 months now and no probs at all.
hi ppl sorry ino it different topic but i need help seroiusly
i have just got my h3 hid kit went to fit it and then i realised the bulb that is in there has 1 wire comin off it (h3) and the hid kit has 2 wires to connect into car wiring
but what i dnt understand is my kit is an h3 kit and the bulbs that are in the car are h3:help::help::help:
H3 bulbs are for the foggers. H7 and H1 in the headlights.
Yes earth the black wire.
Hid bulbs are different to regular bulbs, and have both wires attached.
thnx for your help folks last questions can i earth it anywere?
it wont get hot will it?
am gna connect the red wire off the hid kit to were the original bulb plugs into then earth the other blk wire hw does dat sound??
