Had a fairly good day on the car. Removed all the interior again, but this time the dash came out to get flocked and all the heaters and fans to remove what nots needed out of them. That was fairly easy really. All went very smoothly. I got all of the behind dash soundproofing out which is a pain as most of it is stuck on or behind the fuse pannel!
Then i went to pick up the gearbox internals from the guys who swapped over the broken gears for me (ive still not got the tools i need to separate gears, soon tho). When i got back i double checked them all over, to find that the 2nd gear that was fitted was the wrong one. Its very slightly bigger in diameter
![Doh :doh: :doh:](/forums/styles/seatcupra/oldforumsmileys/doh.gif)
! I did ask them to check it was the correct one. Strange it wasnt as it was from a cupra box?!
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
They had closed by the time i called them so i will have to wait till tmoz to get them to sort a new gear as they have some there. From then on i was in a mood
All the exhaust came off (anyone want a Blueflame cat back???) so i can redo the decat section to run 3" all the way through. Once that was off then the gear linkages came off so i can top mount it all in the car. Im going to need at least a full week on the car to get it finished, but funds are non existent now so i guess that will be after xmas when i can finish
