Need a new induction/filter setup
EZ Tutty
417
Derby
www.eztutty.co.uk
Hey,
I know it's been covered a few times and i have searched, but not really found a definitive answer.
I currently have a green filters open cone, i've had it on for a while now although it's never given me any issues, i'm pretty sure it must be affected by heatsoak/high temperature air.
So i'm looking for some kind of filter setup that keeps the filter and intake temps a bit lower, but it must also provides a good noise from the 007 d/v (i'm so vain i know :happy: )
I've been looking at the Jabba setup with the heatshield, but it's rather expensive.
Also i've been looking at where i could put a cold air feed, however i'm struggling due to still using the standard IC. (FMIC is a project for next year, when i've got over the financial hit of buying a house! :blink: ).
Any recommendations?
EZT
Mat
what bill said.
that's what's on mine IIRC, still get a nice sound from the DV if you're that vein :D
EZ Tutty
417
Derby
www.eztutty.co.uk
Been looking at the dynatwist, and i quite like the look of it, only thing is where to i run the cold air pipe to ? can i just shove it in the wing?
also how does the dynatwist compare to the jabbasport filter & heat shield?
Riko
MURDER WAGON
Jun 10, 2007
1,481
Milton Keynes
I have been wondering about changing my filter also. Would any of the above be better performance and sound over the BCM CDA?? Really wanting a loud grunt/suck...
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Ibiza mk3 Dynatwist feed pipe (80mm) goes up into inner wing where the std one went, just enlarge the foam fitment the std snorkle went thru to secure it.
stani540
349
make your own jabba kit up with a large jetex filter and the jabba heat shield!
shield costs about 50 quid and the cone is less!
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
if you want people to hear all the sound outside the car as well as inside,then a CAI is the way foward
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
trust me you get a real nice induction roar with an echo an as for the dv fook me it dos sound loud atmos loud!! ive had the all ,ive had a jabba one dyntwist ,ram air,an none of them come close to this CAI from ebay for the golf/jetta,,,..........you need to get one,i moded mine so so that the filter sits in the wing rather than low to the ground
james_666
37
question where did you ge tht pipe from i been afterone for ages but cant for the life of me find one
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
I was gonna say, becuase you don;t actually run a hose there right?
I know that for other cars they run a line from the nipple on throttle body...but in your case its blanked off then?
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
no hose on mine at all as the SAI system is all blanked off for me
