Need a new induction/filter setup
james_666
37
whatsort of moddin is required its probably quite simple but have just bought it so would just be nice to know
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
yep i have the same one as peachy, well worth it!
stani540
349
are you both using the cone that came with it???
only thing is i have the universal ic which uses the standard pipe work!
stani540
349
will see seems like a great price!
my cone is a bit of a beast
O/D top 160mm
O/D Bot 140mm
Length 150mm
what you recon will it fit??
jamieread
173
Will i still be able to you this if i have still got the standard Intercooler??
No pipework in the way?
Prob a silly question:redface:
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
Will this jetex filter fit in the gap? what size is the pipe 70mm?
if you want it to fit in the same place mine then your filter may be a bit to large,best thing is just to try it mate an see
yea mate no problem,when i had the filter low i just cut about 50/60mm off the end if you want it low with a std intercooler
