EZ Tutty
417
Derby
www.eztutty.co.uk
Hey,
I know it's been covered a few times and i have searched, but not really found a definitive answer.
I currently have a green filters open cone, i've had it on for a while now although it's never given me any issues, i'm pretty sure it must be affected by heatsoak/high temperature air.
So i'm looking for some kind of filter setup that keeps the filter and intake temps a bit lower, but it must also provides a good noise from the 007 d/v (i'm so vain i know :happy: )
I've been looking at the Jabba setup with the heatshield, but it's rather expensive.
Also i've been looking at where i could put a cold air feed, however i'm struggling due to still using the standard IC. (FMIC is a project for next year, when i've got over the financial hit of buying a house! :blink: ).
Any recommendations?
EZT
what bill said.
that's what's on mine IIRC, still get a nice sound from the DV if you're that vein :D
Been looking at the dynatwist, and i quite like the look of it, only thing is where to i run the cold air pipe to ? can i just shove it in the wing?
also how does the dynatwist compare to the jabbasport filter & heat shield?
I have been wondering about changing my filter also. Would any of the above be better performance and sound over the BCM CDA?? Really wanting a loud grunt/suck...
Ibiza mk3 Dynatwist feed pipe (80mm) goes up into inner wing where the std one went, just enlarge the foam fitment the std snorkle went thru to secure it.
make your own jabba kit up with a large jetex filter and the jabba heat shield!
shield costs about 50 quid and the cone is less!
if you want people to hear all the sound outside the car as well as inside,then a CAI is the way foward
trust me you get a real nice induction roar with an echo an as for the dv fook me it dos sound loud atmos loud!! ive had the all ,ive had a jabba one dyntwist ,ram air,an none of them come close to this CAI from ebay for the golf/jetta,,,..........you need to get one,i moded mine so so that the filter sits in the wing rather than low to the ground
question where did you ge tht pipe from i been afterone for ages but cant for the life of me find one
I was gonna say, becuase you don;t actually run a hose there right?
I know that for other cars they run a line from the nipple on throttle body...but in your case its blanked off then?
no hose on mine at all as the SAI system is all blanked off for me
