Just used this information to try and cure a rattle in my 04 LCR that sounded like it was coming from the dash and sure enough it cured the rattle and i couldnt be happier !
BUT.....
Instead of the alarm box having come loose and forward, touching on the wiper linkage. The box was as far back as it could go. So i thought that can't be the rattle. But after grabbing and trying to wiggle the box to see if it was secure, i found the box was rubbing/squeaking/rattling against the bulkhead as the bulkhead padding is cut out around where the alarm box sits in my LCR.
SO.....
A simple bit of old foam lying around the garrege was used to pad the rear of the box to the bulkhead, i then pushed up against the box trapping the foam in place then securely tightened the 13mm bolt holding it in place.
After two or three long, bumpy roadtests there is no sign of the noise woop woop
Just thought I would post this as i know the more suggestions the better when it comes to finding rattles ( I should know, work on Renaults for a living
So thanks for the heads up James
Arge
