You can read it with http://www.maltchev.com/kiti/
VAG TACHO but it costs.
You can't use your vag com lead with it either
It isn't the transponder that is being programmed, it's the immobiliser control unit in the dash panel. The VAG diagnostic equipment or 1551 code reader provides the programming interface.
The only process I've seen requires that all the keys to be used on the car are present so that they can all be registered with the immobiliser one after another. I assume this means that the process starts by wiping existing keys from the memory. This would be good security, as it makes certain that the keys you have, and only the keys you have, are registered with the immobiliser.
Depending on the version of the immobiliser, they must also get hold of a security code from VAG, using the diagnostic equipment, which is sent directly to the equipment itself, not emailed or written down. Finally they have to make sure all the keys work. So there is a bit of work involved, and it could take up to an hour in some cases, I guess.
Did they ask you to provide all the keys, or just one? I know others have posted on here about having just one key added to the immobiliser, so I guess it must be possible, but the process isn't one I've seen published. Mind you, you don't want it to be easy![]()
my local didnt do a very good job with the cut, so its useless now.
i've searched ebay but can only find the pin end and i need a rounded end for the fob.... does anyone know where i can get one from?
thanks!
I've had Ford and Vauxhall dealers cut keys that would not work - then discovered that for the same price they could have ordered up a proper Ford/Vauxhall key from the factory supplier - they always worked well. The dealers always claimed this was entirely due to the locks being worn - so why did the correct new keys always work! Have you tried getting your dealer to order in a precut "half switch-blade" key - there are available either together, or top half or bottom half.
just to add, i've mine booked in tomorrow and will cost about £70 all in for key cutting and programming.
They said i will need to leave the car with them as will take about 30-45mins a car.
Will let you know how it goes tomorrow and will try to find out how long takes etc
cheers r6, i wasn't intending question your knowledge, just didn't wish to waste the money on wrong ones from them.
will order today and see what goes then.
should be a simple sticky guide for this with a list of needs and actions so we don;t 6million threads, then again won't stop people missing it and starting another....
