the jack supplied with the car is the worst bit of engineering ever.
I jacked mine up away from home once and the car moved a bit which bent the jack, the car fell off it and buried itself into the curved bit of the sill underneath. It made a right mess.
I use a trolley jack with one of those attachments with a pin coiming right out of it which will go into those holes covered by grommets under the car behind the sills, i'm pretty sure these are what hold the car up when they are made
