Where are the jack points?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
front is the rear mount on the subframe , look under the car , round silver coloured jobbie with a big bush in it ,
rear , try using the mount where the rear axle mounts too,
alwaya use axle stands fella , better safe than sorry ,
muddyboots
Still hanging around
Oct 16, 2002
5,739
Tyre places often seem to jack on the front-to-rear box section under the front footwells, which are covered in plastic.
spyke85
I Like Cheese!
Oct 26, 2003
2,247
Bolton
Visit site
Any pictures of the general areas of the jacking areas to lift up front and rear ends? Taking off front wheels tomorrow to paint brake calipers.
gazjones
there are also two box sections that run from roughly middle of the car forward i use these as they are very strong and mean you can put axle stand out of the wasy of the engine bay if im under that part of the car!
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
Are these places where it can be jacked up from the front and back, or is there one of these each side? I want to jack it up from the front and then place on axle stands rather than doing one side then the other.
Yella Beeza
Now which way?
Jun 4, 2007
497
Edinburgh
Yes, run your finger along the sill. There are two indentations, one near the front and one near the back of the sill. This marks the jacking points.
I use a Vauxhall (!) jack - seems stronger than the Seat one. Fits in the chassis rail nicely (use some padding so as not to damage the paint). Then if you are working under the car, some axle stands.
PS Been away for a while (shift in priorities in life!), but I'm back. :)
kriso
Jan 29, 2007
2,325
Brighton
Welcome back, Yella Beeza :) I just realised how old this thread was when I posted too! But I really wanted to know if there were jacking points at the front or back in the middle of the car, cos I wanted to just lift the whole front of the car up and place it straight on stands.
Yella Beeza
Now which way?
Jun 4, 2007
497
Edinburgh
Gosh, you're right. I never even had the car when 'gazjones' posted the reply! And his Ibiza has long gone now.
My car's now a year old with only 600+ miles on the clock. Last time I put BP Ultimate in it, it was about 15p a litre cheaper!! Just haven't had a chance to use it much. And keeping the winter salt off it as well.
kriso
Jan 29, 2007
2,325
Brighton
Sorry to keep asking and it looks like the answer's no but I'll ask one last time! Is there a jacking point on the car where I can jack it up from the front/back only or is it only possible to raise it one side, stick an axle stand underneath and then raise it on the other side?
kriso
Jan 29, 2007
2,325
Brighton
Well I lifted the back on the rear beam, as recommended in the mk3 forum, and supported it with axle stands. Now I need to take a front wheel off and don't fancy using the oem jack.
Is it ok to left with a trolley jack on one side and just place on one axle stand?
Or do I need to lift one side then support with an axle stand, and then lift the other side and support that?
I found this pic of anyone needs it which shows jacking points for the mk4.
tdi sport
68
i tried lifting them parts 1 at a time with a trolly jack a pushed 1 0f them in a a bit so didnt contuine i cut a v into three pieces of wood and placed them under the sills on the axle stands and the third to put on the jack so as not to bend the lip that runs along the lenth of the underneath of the sill hope this helps
ettlz
141
Yes, yes, simple question, I know. But I've never needed to jack it up before. On other cars there are marks embossed on the bodywork showing where they are --- and according to the manual there should be "recesses" on the Ibiza.
Well I'm buggered if I can find them on mine. :confused: Do I just push the top part of the jack onto the ridge that hangs down from the sill, somewhere within 17cm from the wheel arch?
ettlz
141
kriso, thanks for the diagram. I'll put a copy in the manual for reference! I think I spotted these points when looking under it (they have black caps, right?) but I'm not sure they're appropriate for the supplied jack in the spare kit.
kriso
Jan 29, 2007
2,325
Brighton
I had some trouble actually locating these points on the car.
You're probably better off with a trolley jack. You can jack it up at the center of the rear beam from the back. Or along the long box bits that run along each side of the front half of the car.
The Ibiza doesn't have very good jacking points really.
ettlz
141
Hmm... I have 9N1 Polo sitting right next to it. This one does have marked points. I guess their infrastructure is pretty much the same... :think: it's just that the area concerned looks more like bodywork, but all things being equal it should be able to support around 300kg...
Andybon
BOOYAH!!!
Nov 1, 2007
310
St Helens
Looks like on mine that someone jacked it up on the cill at some point and bent all the metal lip along the bottom.
