small update.
got the new maf on and it went back for mapping.
came back with same problems. but they are now putting it down to compressor surge. however im not convinced.
they also said once it pulled thru the surge it made 460bhp, but once again im not convinced.
currently looking to have it mapped again at my cost.
i also managed to snap the turbo support bracket so i now have a stonger model its not stainless anymore, thicker, and has a strengthening fold
HoocH
alrady spoke to bill and he cant do it.
found out cc can do it but only at jbs
minimvic,is your car throttle cable driven?If so i would go for Autronics,get in contact with Mark at MA Developments he is down your way.
Hooch
I was talking to the guy that bought danish's a3Q at inters.
That car had lots of issues with mapping, but apparently chip wizard (wayne) sorted it. The turbo is an owens hybrid, but 3071 sized.
If it's comp surge in high gears during boost onset, try moving the n75 boost take off from the pipe, after the compressor to the intake manifold.
Both caney and I have what sounds like dv flutter but has been put down as comp surge until now. I've been reading around scooby bb's, and they have problems with dv lifting during boost onset, which is cured by taking the boost signal from post throttle body, rather than pre ic.
As for high airflow causing problems, well fit a maf large enough that you won't saturate it, and do the same with the map.
its got some home brew boost controller/bleed valve on it
