How do you remove the rear light cluster?
Phil_beeza
461
how dya remove the rear light cluster?
i've removed 2 torx from the back next to it. is there something inside i need to remove?
thx!
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Push fairly hard on the side of the light - like if you stand so you are facing the rear quarter panel - press on the edge of the light and pull. It should come out then. :) They are a pain! :lol:
Phil_beeza
461
ok so say i am on the right hand side light as i am looking at the back, i get my right hand, palm facing forwards, get my fingers round the left hand side of the light, and pullll?
Phil_beeza
461
cool ok, it sounded like there was another bolt holding just behind where the indicator position is. but i'll pull. :)
Phil_beeza
461
oh yeah. done. easy. :) id recommend using a wide flatblade screwdriver wrapped in tissue, on the outside edge of the lights, all it takes is 5mm worth of prising at the right place
Tricky Red
75
I did that and now i'll be £50 lighter as the lens broke at the point you said. I had a wide flat blade wrapped in a microfibre cloth and it still broke.
Be careful with screwdrivers.
Torquemonster
301
:( I got the dealer to change my bulb.Halfords wouldn' touch it,it came up on his screen 'do not attempt to fit,danger of damage to light cluster,refer to dealer'.I'm a bit useless with practical things,so i did.:redface:
bizzaboy
That's all good for pulling out the 'outer' lens clusters. :)
But any tips on removing the INNER clusters, that fit to the tailgate? :)
I located a screw quite deep in the unit, removed this, however there must be more screws somewhere.
All feedback appreciated! ;)
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
That's EASY! Take the covers off the inside of the boot - remove 4 posidrive screws and lights come out. Piece of pi55. :D
Badger
2,888
7
Newcastle, Staffs
Remove the wires and bulb holders.
You need a limescale bathroom cleaner and water. Place it inside and shake to death. This should free up the crap and rinse out. Ensure you dry them fully before you put them back on.
JamesA
23
Used one of those hook pull tools designed for laying laminate flooring to remove mine.
A wider contact point than a screwdriver.
Matas
14
Leeds
Mine both came out really easy after taking the screws out, I guess the previous owner had them out not long before I bought my car.
