What power are people running in their mk2 ibizas?
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
dunno what mines running at (should really get to a RR day, shouldnt I??) but its got the secret of monkey power pushing it , too ..:D
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
puts a lot of 20vt's to shame!! dare i ask for the spec list!!:lol: i take it that's yours on the youtube being dyno'd?
Didn't know it was on youtube - where ?
Its a 2L short block, 144mm Carillo H-rods, 12:1 Accralite forged pistons with valve cutouts, VW forged crank, ARP fasteners throughout
Flowed head with bigger one piece stainless valves in/out, solid lifters (Arrow)
Titanium valve caps, Catcams high lift springs, billet Catcams cams (280+ and very high lift), vernier cam wheels
Titan / F3 dry sump
Lumenition 451 dizzy triggered ECU with lumenition coil amps and vauxhall XE coil
Custom under-drive pully on crank (90mm dia down from 135mm) slowing waterpump and alternator which have std size pullies
Billet power steering and waterpump pullies (stock dia)
New alternator / little gel battery in car
Badger-5 DTH 45mm TB's with cossie beige injectors and custom billet rampipes, Jenvey custom phenolic gasket to head to stop heat conduction
ITG cossie DFV JC70 filter
Awesome Mk2 Golf GTI 4-1 manifold with enlarged collector, lambda added, and whole lot 4 layer ceramic coated inside and outside, 2.5" stainless system to back, one big repackable silencer at rear
Autotec ali G60 flywheel precision drilled to take ARP flywheel bolts
Spec stage 1 VR6 clutch - organic type for smoother takeup than paddle kind (found its better off the line and is lasting well - supposed to be good for 300 lbft - sprints are short events so not too much time for heat buildup which is probably why its ok)
Radtec WRC-spec short radiator with samco / custom ali plumbing
LOTS of messing about time.....
Currently at a bit of a decision point with it - to keep developing with bigger TB's, better (newer) engine management, higher spec fuel which will give me probably another 20-30hp
OR
Build a 1.4 Turbo (see separate thread)
OR
Sell up at end of year and build a motorbike-engined single seater
Decisions decisions
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
That must stand you in a fair amount Rob! El rapido though!
I dont want to think about it :headhurt: very quick car now, competition proven, nearly always the fastest atmo saloon at sprints and hillclimbs (couple exceptions when british championship boys turn up)
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
wow thats alot of work you have done and i bet its alot of fun?!how could you think of selling up after all the time money and effort in?altho the other projects sound interestin!
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Yeh thats it - 236 I think that day, done a bit more optimisation since, 248 a couple months ago
goes like stink - nothing like big turbo power but totally instant throttle response in what is quite a light car now - not bad power for an atmo car
beezertart
**MAYHEM**
Sep 11, 2007
1,260
beyond the sun
Had mine rollered at AMD today,whilst i hid at Maccy D's as scared to watch:p petrified she was gonna die as she seemed a bit sluggish n temperamental of late....came back,car still alive and was well chuffed with my 132bhp n 140.5lb/ft torque on a totally standard 115bhp book car:D even though i know they put out more than quoted didn't expect 17free ponies on a 10yr old car!!!
