South Wales Cupras Chat
Status
Not open for further replies.
Dec 3, 2007
2,475
cardiff
well i dont think i have any boost leeks from those pipes as i have checked them all. My n75 had a leak on the pipe that went to charge pipe. I know that because there was oil around it. This might have been it. But like i said. I dont know the colour of smoke but was told blue and then told darker than blue.
Dec 3, 2007
2,475
cardiff
u saying go out and belt the car to do the logs. its really busy so i could do them in 3rd gear not 4th if thats going to be ok
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
The one with the thickest wire. 4awg or thicker it needs to be.
I'm using 4awg and jonzy if using 0awg, which is thicker.
I was looking at 4awg pro gold (i think) wiring kit, but there were
400w , 800w or 1500w all 4awg.
I hate this kinda stuff, I never know!
I also saw the fusion one's which i think you said you had, the 800w had a bright red kinda see through covering, where as the 1500w kit had a more darker flat colour red.
Dec 3, 2007
2,475
cardiff
ok. Well my cat is fine then. I have checked spark plug's. Compression. Block020. I will check my turbo tomorrow. Anything else any one can think of?
Nov 2, 2004
9,335
South Wales
I didnt fuse it tom, no. No problems at all with it.
Oil in fmic/smic pipes, boost/vac leaks, shaft play in the turbo, oil consumption, MAF readings, fault codes, petrol consumption.
Nov 2, 2004
9,335
South Wales
Got my new Griffin iTrip for the car on the weekend for my iPhone, and fair play, what a piece of kit, sound quality is top notch fair play. :D
Nov 2, 2004
9,335
South Wales
Tempted to go for a blast tonight as the weathers looking good...
From where i live, over the Rhigos mountain, then from Hirwaun on one of the best roads about A4059 then down the A470 to Merthyr, back to hirwaun on the A465 and back over the Rhigos.
Dec 3, 2007
2,475
cardiff
ok thats a fair list. If i have oil in intercooler what do i do? I think i saw oil in tip the other day.
Rhys i finish at 8. We can do logs if u want.
Any thing i should log? To aid in my search. I know maf and i think rhys know's the block. And will do 020 properly this time. What else?
Status
