sure,post in here
http://www.seatcupra.net/forums/forumdisplay.php?f=60
we are not just SEAT fans,so long as its good![]()
Think his car will fall under the topic general motorsport
http://www.driving-fun.com/forum/viewtopic.php?t=3346&highlight=aram
sure,post in here
what brake set up are you running ? im guessing big lol
excuse my ignorance, but why have such huge brakes at the rear of the car ?
because i am cheating!!! the regs have banned active differentials (ie the electronic adjustment of differential hydraulic pressure to modify in real time the friction characteristics of the cross axle clutch pack) that allowed us to get good traction and modify the cars yaw damping in response to handwheel position and lateral G, both on entry and exit to a corner.
HOWEVER, they dont say that you cannot run a mechanical diff, that just happens to have very aggressive negative torque ramps, and then use the rear brakes asymetrically to er, "adjust" the diff preload and hence torque biasing across that axle. But as a result you have a situation where you are effectively absorbing the excess tractive effort into the brake system for that axle, hence the large rear brakes!
What the handling going to be like running RWD with the ibizas short wheel base?
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
huge? they are small compared to the front - lolexcuse my ignorance, but why have such huge brakes at the rear of the car ?
