to help people that are buying the new Nomad pod with the screw at the top. remove the top plastic clip from the car and use one of these (cut in half) and an M10 washer.
you can then cut a piece of wood to the right thickness and screw to the car.... after just screw the pod to the wood. it's solid.
Quick question, i noticed the other day that if i turn the lights down via the dimmer switch then the needle on the oil temp gauge goes down with it. Anyone elses do this?
It will do if you've attached the guage light feed to the dimmer wire...
If you don't want this to happen then you need to fit it to a ignition live wire.
hi there, got the wires sorted out it think, where did you ground sender wire to
I took mine straight to the neg terminal on the battery...just to be safe.
