has any one removed this as i presume it would have to come of to remove the sub frame mine is lc not "r" but i would have thought this bit would be the same.
need a guide anyone
Mine's an LC too. You can see from my pictures that the subframe can drop/remove without taking the lower brace off.
The subframe is held in by four bolts, two front, two rear. You need to take out the bolts that hold the steering rack to the subframe, leaving the rack hanging. Also need to take out the forward two dogbone mount bolts.
