green panel filter fitting
satilaboy
375
just bought a used green panel filter which i'll clean prior to fitting.
do i need to disconnect the maf hose prior to fitting or does the lid of the airbox come off without having to touch this?
if there is any crap in the airbox is it safe enough to give it a quick hoover?
cheers,
sheffboy
avoiding potholes
May 25, 2007
655
The lid of the airbox just pulls up enough to get the filter in without disconnecting the MAF. I cant see any problems with giving it a vac. Make sure you re-oil the filter though after cleaning it.
D.K
LCR 225
Oct 24, 2007
6,408
se london
I might be wrong but aint it the oil that screws up the MAF
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
I think thats right DK, thats why the K&N ones aren't really up to the job. They rely on oil to catch the dust.
I cleaned my green one and didn't oil it exactly for that reason. I am sure they are ok to run dry.
satilaboy
375
can you use K&N cleaning solution and oil on the green filter??? having seen both they seem to differ only in colour (the oil/solution i mean)
I can buy the K&N locally but i'd have to order the green oil/solution.
sheffboy
avoiding potholes
May 25, 2007
655
I'm just following the manufacturers instructions. i would of thought they'd know the best way to treat the filters :confused:
obviously dont lard it up with oil. It states to spray a small amount on after cleaning.
Had mine 2 years, cleaned it four times and had no maf problems.
L3DNT
My Green is foam, arent K&N's not paper filters usually? Therefore different cleaner and oil needed?
satilaboy
375
i undid the screws but the lid only pops up at the side with the screws and even then only a little, i tried to prise out the old filter but it's a struggle.
should the lid pop up at both the side with the clips and the side with the screws?
I might end up unscrewing the maf tube bit. hoped to avoid this though.
satilaboy
375
anyone?
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Once you have undone the screws, you should be able to pop it off the clips on the other side too. The whole airbox lid should move away on the Inlet Pipe enough for you to get the filter out.
satilaboy
375
got it. was just worried incase i broke it but with a little persuasion it unclipped.
cheers
