Revo Stage 2 K03s Logs
Powerstation run a Mahaa dyno mate, I pulled 226bhp on a K03 there, a remapped LCR pulled 266bhp so the results are pretty bang on...they'll plot your boost too...
http://www.westover.org.uk/si/power/martyn.pdf - My old Ibiza pre K03s
http://www.westover.org.uk/si/power/si.pdf - Si's remapped LCR.
My log from Guesstec last time I came down...(K03s + mani)
main.php
Nov 2, 2004
9,335
South Wales
Gonna be logging the car tomorrow night, i put my MAP sensor back on tonight, well jonzy did and i'm not convince its sealing right so i'll soon find out on my logs.
Will also change my plugs before i got and do a TBA.
-pseudonymous-
681
Funny you should mention your MAP sensor Phil cos my car went into limp last night and i got the following fault code
16490/P0106/000262 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
Not sure if my MAP sensor is playing up or if its something else.
What blocks you gonna be logging? can you get a 114 and 031 for me to compare?
-pseudonymous-
681
Yeah as its mounted in the pipe from the turbo to the intercooler so would leak boost or either give no reading or erratic readings if faulty i would have thought.
Nov 2, 2004
9,335
South Wales
I managed to get out and do a small 3rd gear 118 log before i **** out/run out of room, at least i know my map sensor isnt leaking. :D
