I have spent the day looking into the DPF (yes to much time on my hands i know)and from reading the driving style is not the problem, if you driving style does not allow for passive regeneration of the DPF then the car initiates active regeneration, active regeneration is designed for people who don’t do enough driving to allow the filter to regenerate by its self, this is the fail safe, it seams that the VAG active regeneration system is not working correctly, although other manufactured has suffered from problem the most I have been able to find is with VAG cars, the active regeneration system when fully completed should always clear the problem.
From reading the forum most people seem to have the first light come on then go off then some time later it seems to come back with the management light and enter limp mode.
f it was driver error you would get the first light, this would remain on until the second stage kicks in and put the car into limp mode.
